Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Show Parts for Model:
Re: 420 won't start
Dave H
07-23-2013 04:53:54
either spark or gas. I would first pull the plug on the bottom of the crb and turn the gas on. If it does not have a steady stream coming out then you need to run that gas prob down.
if that is good jump a wire from the hot cable on the starter to the side of the coil that is not hooked to the dist. Crank and see what happens.
post back
JD Gimpl
07-23-2013 08:16:51
 Re: 420 won't start in reply to Dave H, 07-23-2013 04:53:54
Fuel comes out fine.
Dave what should happen when I jump the wire to the coil?
Thanks Gimpl
Dave H
07-24-2013 04:59:43
 Re: 420 won't start in reply to JD Gimpl, 07-23-2013 08:16:51
that just circumvents all the wiring in the harness and provides the voltage direct. That is where you should have 6 volts when you turn the switch on.
I ran mine like that for a while until the new switch came in.
JD Gimpl
07-24-2013 18:13:51
 Re: 420 won't start in reply to Dave H, 07-24-2013 04:59:43
Hi Dave,
I got it started by bump starting it behind the SUV today. Runs ok for a few minutes and trys to die like it is starved of fuel. I did pull the plug and fuel came out steady for a minute I ran it.
Would the switch cause problems intermitent?
Gimpl
