Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Show Parts for Model:
Re: John Deere 2150 Over Heating..??
Canadian Ken
07-21-2013 18:07:19
Possibly the head gasket is blown pressurizing the cooling chamber
If you have a cooling system pressure tester - install tester on rad cap opening and start tractor
Rad caps are usually 13-15 psi While tractor is running, see if pressure goes past 15 psi and keeps climbing - if so it is the head gasket
I had a 6910 European model tractor that did this -pressure went all the way to the end of the gauge -started out I was to change the thermostat, I moved the tractor and let it run for 5 minutes -removed the thermostat bypass hose and the coolant exploded on me - there should not be that much pressure in cooling system in 5 minutes of running -head gasket was problem
Ken
Copyright © 1997-2015 Yesterday's Tractor Co.
