Yesterday's Tractor Co.
Shop Now View Cart
Show Parts for Model:
Re: JD 4430 power steering problem
Tim S
07-21-2013 10:07:29
Yep that's what I was trying to get on there,,seemed like every time I would set the image it took over the entire screen,,Darn it,,I am having a bit of trouble with my Mozilla program,,waiting on my "Geek" to make a house call...Changing these over helps a lot with those darn push on hoses and the check valve is a lot of times the reason for hard steer, I haven't found a real good way to prove these yet, but I am working on a way to bench test the metering pump on my stand...
07-21-2013 17:35:38
 Re: JD 4430 power steering problem in reply to Tim S, 07-21-2013 10:07:29
Could I have air in the lines since I had several lines disconnected? I can cycle the steering wheel several times and the PS works for a while. Thanks for your help. Roy
Tim S
07-21-2013 17:41:22
 Re: JD 4430 power steering problem in reply to lemroy, 07-21-2013 17:35:38
No, air in the lines has a way of purging it's self out,,I'm still leaning to the check valve in the steering metering pump. You will need to disassemble it to remove the valve fittings, and it's not as bad as it seems...
