TractorLinks.com
Show Parts for Model:
Re: JD 4430 power steering problem
Tim S
07-21-2013 09:30:47
AR86492 Hydraulic Hose ADD 34.87 USD 34.87 USD
AR86490 Hydraulic Hose ADD 43.07 USD 43.07 USD
R55243 Shim ADD 1.06 USD 2.12 USD
AR88771 Check Valve ADD 82.74 USD 82.74 USD
R68220 Fitting ADD 19.12 USD 19.12 USD
R28776 O-Ring ADD 1.09 USD 4.36 USD
R72858 Seal ADD 5.88 USD 5.88 USD
R27272 Fitting ADD 6.01 USD 6.01 USD
R26286 O-Ring ADD 1.30 USD 1.30 USD
Parts that have an issue will display a flag. *Subtotal 199.47 USD *Total 199.
Tim S
07-21-2013 09:32:34
 Re: JD 4430 power steering problem in reply to Tim S, 07-21-2013 09:30:47
This did not transfer well you will need 2 R55243 shim/Gaskets
4 R28776 o-rings
Tim S
07-21-2013 09:41:14
 Re: JD 4430 power steering problem in reply to Tim S, 07-21-2013 09:32:34
I'm having trouble with a parts pic, but go to 4440 steering metering pump, and rear steering lines in the parts site to see what i'm talking about
Tx Jim
07-21-2013 09:51:01
 Re: JD 4430 power steering problem in reply to Tim S, 07-21-2013 09:41:14
Tim I'll give you a little help.
This post was edited by Tx Jim at 10:00:10 07/21/13.
Tim S
07-21-2013 10:09:36
 Re: JD 4430 power steering problem in reply to Tx Jim, 07-21-2013 09:51:01
14-B and 12-B are the 2 fittings needed,14-B is the check valve fitting
Tim S
07-21-2013 10:07:29
Yep that's what I was trying to get on there,,seemed like every time I would set the image it took over the entire screen,,Darn it,,I am having a bit of trouble with my Mozilla program,,waiting on my "Geek" to make a house call...Changing these over helps a lot with those darn push on hoses and the check valve is a lot of times the reason for hard steer, I haven't found a real good way to prove these yet, but I am working on a way to bench test the metering pump on my stand...
lemroy
07-21-2013 17:35:38
 Re: JD 4430 power steering problem in reply to Tim S, 07-21-2013 10:07:29
Could I have air in the lines since I had several lines disconnected? I can cycle the steering wheel several times and the PS works for a while. Thanks for your help. Roy
Tim S
07-21-2013 17:41:22
 Re: JD 4430 power steering problem in reply to lemroy, 07-21-2013 17:35:38
No, air in the lines has a way of purging it's self out,,I'm still leaning to the check valve in the steering metering pump. You will need to disassemble it to remove the valve fittings, and it's not as bad as it seems...
