TractorLinks.com
Show Parts for Model:
Re: John Deere A flywheel
elkcagg
07-20-2013 17:03:45
Do you have an indicator with a magnetic base? This is the most accurate way to check. If not, if you can pull back & forth on the flywheel after its tightened and only see slight movement back & forth is good enough then. Another way to check is watch your flywheel or pulley as you engage the clutch. If your clearance is excessive you will be able to see it move side to side as you engage & disengage.
