Yesterday's Tractor Co.
Shop Now View Cart
Show Parts for Model:
Re: John Deere A flywheel
07-20-2013 16:02:21
Ok, got the oil slinger lined up and the flywheel is now back where it belongs. Aparently it was not right from the get go.
Now please explain where I need the .005-.010 clearance.
Forgive me. Can be a bit dense sometimes. Just want to be sure I'm doing it right.
07-20-2013 17:03:45
 Re: John Deere A flywheel in reply to mountaindog, 07-20-2013 16:02:21
Do you have an indicator with a magnetic base? This is the most accurate way to check. If not, if you can pull back & forth on the flywheel after its tightened and only see slight movement back & forth is good enough then. Another way to check is watch your flywheel or pulley as you engage the clutch. If your clearance is excessive you will be able to see it move side to side as you engage & disengage.
