TractorLinks.com
Show Parts for Model:
Re: John Deere A flywheel
elkcagg
07-20-2013 15:34:24
Yes, the flat on the crank lines up with the setscrew in flywheel and if the flywheel is the only thing you removed for painting then the notch in the oil slinger should still be in time on the crank. I usually look for V marks on the end of crank & flywheel spline before removal. If these are not present before removal I usually punch mark or use a paint marker so I get them on the same way they came off because not all cranks have this flat. Very important to get this right but it sounds like you are on the right path. You just need someone on the pulley side to get your .005/.010 clearance. I hope this helps.
