TractorLinks.com
Show Parts for Model:
Re: John Deere A flywheel
mountaindog
07-20-2013 10:19:41
Ok, now I understand. I'll have to wait till I get help later today to pull it back off and look. I put it back where it was but that don't say the previous owner did it right. The one spline on the crank has a small set screw in it which lines up with the key way slot in the flywheel. At least that's the way it was when I took it apart.
elkcagg
07-20-2013 15:34:24
 Re: John Deere A flywheel in reply to mountaindog, 07-20-2013 10:19:41
Yes, the flat on the crank lines up with the setscrew in flywheel and if the flywheel is the only thing you removed for painting then the notch in the oil slinger should still be in time on the crank. I usually look for V marks on the end of crank & flywheel spline before removal. If these are not present before removal I usually punch mark or use a paint marker so I get them on the same way they came off because not all cranks have this flat. Very important to get this right but it sounds like you are on the right path. You just need someone on the pulley side to get your .005/.010 clearance. I hope this helps.
