Rear Break away leaking
KRS_MED
Rear SCV remotes are leaking on my 2150. I bought the SCV and remotes used but it all bolted right. The number on the breakaway coupler is R39109, but I can't cross that number. It has the caps on top, with the levers on bottom. It very hard to connect the hydraulic line. It seems that the coupler is not going in far enough. Plus they leak when nothing is hooked up but don't leak when you finally get line in. The hydraulic hose has new coupler on it from JD (they made the line). Any help or advise on what kit or how to repair would be a great help.
Keith
It appears your breakaway coupler is one of the earliest styles. It fits many different models from the 20 through 40 series utility tractors. I found this in a 2020 PC Read parts description for parts key #22 AR52621 COUPLING 1 R.H. (SINGLE) (MARKED R39109).
Leaking out of the barrel with nothing attached is an indication that the ball(parts key #25) isn't seating. AR82570 Breakaway Coupler kit ADD 24.46 USD
(quoted from post at 16:40:44 07/17/13) Jim the diqagram isnt showing up? Thanks Keith
You're correct as I forgot to upload photo.
