TractorLinks.com
Show Parts for Model:
Re: 2010 Hydraulic/Trans fluid leak??
Jo Bird
07-17-2013 16:59:41
Have you looked in the round hole on the left side of the clutch housing or taken the rectangular cover off the bottom of the clutch housing to see if you can tell where it is leaking from ?? How are the fluid levels in the transmission and engine ? Several areas it could come from such as the line to the power steering, "O" rings to the remote valve on the top of transmission front cover, cover to the proportioning valve, hdy pump it's self, back side of the hdy pump mating to transmission front cover or the oil seal on the clutch throw-out bearing carrier. If the oil is black it could be the engine rear main seal. Sorry I don't have a spot on location for your leak, it's one of those look-see whats leaking things. Just offering moral support before the 2010 basher's show up..LOL.
Jo
BobH in NH
07-17-2013 17:59:33
 Re: 2010 Hydraulic/Trans fluid leak?? in reply to Jo Bird, 07-17-2013 16:59:41
Thanks for the ideas. I had studied the SM and the Parts Manual so I knew what was in there. Definitely not engine oil as it was clear. And working the PS and Hydraulic with tractor running but not moving did not cause leakage. But moving the tractor with no hydraulic or PTO use did cause leaking, but it stopped quickly when I parked the tractor, with engine running.
So I am leaning towards the drive shaft input to transmission. Was too hot to really check, and I have been tied up today so haven"t been able to pull the two covers.
Yes, I know all about the 2010 bashers. Tractor with a super bad rep, but this is a late "64 model and has been really reliable, except for some starter issues (Parts N/A for the Prestolite used on the Diesel model).
Dug out the Power-Trol I bought for our old "44 A and guess I will pull the power lift and install this. I have run the NH 477 with it numerous times before, and it should handle the little Hesston 5530 OK.
