BobH in NH
2010 started leaking significant amount of fluid from weep hole on joint where trans housing meets clutch housing. Noticed it after cutting for several hours with haybine. Seems to be transmission related as I could not duplicated by exercising the remotes. Also started leaking again when I hooked tractor up to round baler. But it didn"t appear to be leaking when I checked after ejecting a bale.
Anyone have experience with this issue? I am between a rock and a hard place as this is the only tractor I have to run the baler and haybine. I do have the SM and Parts Manual.
Thanks.
Thanks.
