TractorLinks.com
Show Parts for Model:
Re: hayrake
Bob
07-16-2013 11:36:21
Well, the thread title is "hayrake" and you are looking for a fan belt for a TRACTOR which does NOT have a fan belt, as the fan is gear driven.
If this is a legitimate question, you must be looking for a GENERATOR belt.
Serial numbers B60,000 through B306599 use a DEERE #B1587R generator belt.
Serial numbers B306,600 and up use a DEERE #B2893R generator belt. I would think yours must be in this range.
BOTH should be readily available through your nearest DEERE dealer. IF they don"t have the one you need ask them to put it on the next stock order to arrive in a couple of days (IF you can wait) to save special-order freight.
#B1587R
Belt Section 4L
Effective Length 29.100 IN
Width 0.497 IN
Thickness 0.297 IN
Angle 36
Material Spec PREM
#B2893R
Belt Section 13A
Length 40.500 IN
Width 0.500 IN
Thickness 0.331 IN
Angle 40.000
Material Spec POLYE
Basil Greenleaf
07-16-2013 12:42:00
 Re: hayrake in reply to Bob, 07-16-2013 11:36:21
Thank you for the belt info. I do not have a clue as to how the word hayrake got there. I labeled it JD B. You are right I should have called it generator belt. Thanks, Basil
