TractorLinks.com
Show Parts for Model:
Re: DBG Roosa- Master on 4020
cooop
07-16-2013 08:17:20
It would be nearly impossible to do it on the tractor because the weights in the the weight cage would want to fall down because the pump is vertical. You cant put the weights in the pump before either because of the snap ring that holds the weight cage on the rotor. You will need the pump removed. Remember to time it before removal. Check the return restrictor fitting for debris to be sure this is the problem.
