Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Show Parts for Model:
Re: DBG Roosa- Master on 4020
Bob
07-16-2013 08:11:00
It would be next to IMPOSSIBLE to remove and reinstall the head and rotor and governor assembly with the IP in the installed (vertical) position. ('Cuz the governor would fall apart at any attempt to lower the assembly down into the pump body.)
Have you examined the return fitting/pressure regulating valve or looked into the timing port for coffee-grounds-like debris that would indicate a disintegrating flex ring?
Your problem could also be a sticky metering valve or worn governor linkage.
Copyright © 1997-2015 Yesterday's Tractor Co.
