Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Show Parts for Model:
Re: Can you remove a clutch pulley with the wheel still on?
JGC
07-15-2013 12:42:15
We removed one this past winter. The tractor had long axles so we loosened the clamping mechanism and slid the wheel out about 3" on the axle to gain enough clearance.
SIDE NOTE: The owner wanted a "newer" pulley with less groove wear on the belt surface. The job turned out to be a lot of work because the used pulley he bought had slightly different dimensions than the original pulley and some careful machining was required to gain the clearances required.
Copyright © 1997-2015 Yesterday's Tractor Co.
