TractorLinks.com
Show Parts for Model:
Re: JD 2130 HYDRAULIC FLOW
jown63
07-15-2013 05:51:15
I believe it's plumbed direct but I'm not sure which pump I didn't know there were more than one, can you tell by looking at the pump? Thanks
Tx Jim
07-15-2013 06:08:03
 Re: JD 2130 HYDRAULIC FLOW in reply to jown63, 07-15-2013 05:51:15
Actually there could be 3 different size pumps. 1st photo is middle size and 2nd photo is largest.
jown63
07-15-2013 06:45:05
 Re: JD 2130 HYDRAULIC FLOW in reply to Tx Jim, 07-15-2013 06:08:03
It looks like the middle size one, how much does it put out. Thanks
Tx Jim
07-15-2013 10:39:01
 Re: JD 2130 HYDRAULIC FLOW in reply to jown63, 07-15-2013 06:45:05
I'll guess 10-11 GPM
buickanddeere
07-15-2013 20:38:01
 Re: JD 2130 HYDRAULIC FLOW in reply to Tx Jim, 07-15-2013 10:39:01
wrong guess
Tx Jim
07-16-2013 03:26:05
 Re: JD 2130 HYDRAULIC FLOW in reply to buickanddeere, 07-15-2013 20:38:01
Thanks for correcting my wrong guess with the correct information.
jown63
07-15-2013 06:11:39
Thank you so much.
buickanddeere
07-15-2013 20:35:24
 Re: JD 2130 HYDRAULIC FLOW in reply to jown63, 07-15-2013 06:11:39
Vital to know here what the hydraulic load is and how it's going to be connected. According to the service manual and if the pump recieves enough flow to it's inlet port. The Dubuque/mannheim tractors used either a 1000 series four piston pump with 6.75gpm. A 1000 series eight piston pump with 13.5gpm. Or a 40cm 2000 series pump which your tractor appears to have. Rated at 23.3gpm. Connected through the scv's it isn't going to flow 1/4 of rated. Note all gpm's are under ideal circumstances and at 2500rpm. real world flow will be approx 2/3 to 3/4 of rated.
jown63
07-16-2013 04:22:57
 Re: JD 2130 HYDRAULIC FLOW in reply to buickanddeere, 07-15-2013 20:35:24
Thanks for the info, yes after a closer look at the pump it is the larger pump. Thanks again
