Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Show Parts for Model:
Re: JD 60 wiring
Hayrack
07-05-2013 14:29:20
I have converted several tractors to electronic ignition. The only differences between them and a stock tractor is in the distributor. If you look you will probably have 2 wires coming out from the distributor to the coil instead of one. All the other wiring except for your negative ground is standard. The electronic ignition is sensitive to positive or negative ground so if your gonna keep it (I definitely would) you need to run it as a negative ground system. Follow the stock wiring diagram but flip the wires from terminal to terminal on the amp meter and hook the hot wire of the coil to the positive terminal on the coil. hook your battery up accordingly and other than that and polarizing your generator and regulator, everything is stock. Good luck! :)
