TractorLinks.com
Show Parts for Model:
Re: 720 gas pop and miss??
jturbo10
07-05-2013 10:03:04
I had something similar going with my JD 630 and it was caused by the carb. I would make sure I had a good stream of gas coming out at the carb first and then put in the working carb from you other tractor. You could also put your carb on the working tractor and see what happens there. Either way I would start with the simplest solution and work to the most complex/expensive solution which experience has taught me is the best methodology for old two cylinders. Have you checked your air cleaner bowl? Found one of mine full of water and gunk one time which will also cause similar issues. Has to be one of three issues: not getting proper spark, air, and/or fuel. Good luck Aussie Ken.
