Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Show Parts for Model:
Re: How do you start a John Deere 70 Diesel?
Eric Allen
07-04-2013 20:05:10
Thanks! That sounds doable. I've never used a tractor with a pony before. I've read the 70 set fuel economy records that stood for decades
Tx Jim
07-05-2013 04:14:14
 Re: How do you start a John Deere 70 Diesel? in reply to Eric Allen, 07-04-2013 20:05:10
I thought one was suppose to let diesel engine turn over a few revolutions before pushing throttle forward to give the diesel any fuel. Also be sure and turn ign switch off after diesel starts as pony motor coils are expensive.
coonie minnie
07-05-2013 04:40:59
 Re: How do you start a John Deere 70 Diesel? in reply to Tx Jim, 07-05-2013 04:14:14
You are correct Jim, there are a couple steps missing. The poster would be WELL advised to get a manual.
On my 720, a little different than the 70, I motor the big diesel over with no compression til the oil pressure comes up. Then I release the decompression lever, motoring on full compression, and then advance the throttle, and it will start.
I've never started a 70 with the one lever system, the 720s and 820s I've run all had the separate decompression lever. Can someone on here explain the one lever system??
buck eye al
07-05-2013 14:40:57
 Re: How do you start a John Deere 70 Diesel? in reply to coonie minnie, 07-05-2013 04:40:59
The original single lever process simply energized the cranking engine's starter motor when you pushed it forward. It took a pretty stout push but that's how it worked. The trouble with it was if you pushed too hard when disengaging from the Diesel it was possible to re-engage the cranking engine's starter with the then running (at about 6000 RPM) cranking engine.
Normally this forward motion on that single lever was taking place when the diesel had just started. On the 70D the cranking engine was governed at 6000 (I think they calmed them down a bit on the 720 and 730) and he had just finished his task of starting the diesel so it was going full bore which was NOT a good time to ever bump the starter drive pinion into the flywheel.
They re-designed them starting with 7026869. Earlier 70's could be converted using the AF 2305 starter pedal assembly kit. I have one such "converted" tractor.
Hope that helps.
