Yesterday's Tractor Co.
Shop Now View Cart
Show Parts for Model:
Re: 4010 fuel filter change
Tx Jim
06-30-2013 14:25:07
Just change both filters then open bleed screw(parts key #10) on top filter then pump lever on lift pump to purge the air. When diesel comes out of bleeder,tighten bleeder & crank engine. If when pumping hand pump no resistance is felt bump engine a little to get cam lobe away from lift lever.
AR44077 Filter Element ADD 11.32 USD 22.64 USD
This post was edited by Tx Jim at 14:26:58 06/30/13.
06-30-2013 15:35:06
 Re: 4010 fuel filter change in reply to Tx Jim, 06-30-2013 14:25:07
Can you direct me/him to the lift pump lever?
Tx Jim
06-30-2013 15:42:03
 Re: 4010 fuel filter change in reply to NoelC, 06-30-2013 15:35:06
Lever(parts key #6)
If it has original pump.
06-30-2013 19:18:48
 Re: 4010 fuel filter change in reply to Tx Jim, 06-30-2013 15:42:03
If you can't find the lever they sometimes break off or someone could have installed a fuel pump for gas tractor.
