TractorLinks.com
Show Parts for Model:
Re: voltage regulator wiring diagram
Bob
06-30-2013 10:31:02
"A" or "ARM on regulator to "A" on generator.
"F" or "FLD" on regulator to "F" on generator.
"B" or "BATT" on regulator to ammeter. Other side of Ammeter to ungrounded battery cable at solenoid or starter switch.
Battery goes to one ammeter terminal. Regulator output and ALL electrical loads go to other side of ammeter.
Polarize generator BEFORE startup
by momentarily jumpering "BATT" and "ARM" at regulator.
If ammeter reads backwards, swap wires between the two terminals.
Matt Huls
07-02-2013 20:20:15
 Re: voltage regulator wiring diagram in reply to Bob, 06-30-2013 10:31:02
Lights are wired like so... rear light wired to rear terminal, head lights are wired to head terminal. that at batt terminal I have a wire going to the battery. Is this o.k.?
Matt Huls
07-02-2013 20:14:43
Right now I have the key switch wired like this.... one terminal is wired to the coil and the other terminal is wired to the battery ? Is this right?
Matt Huls
07-02-2013 20:11:17
Whats the best way to ground the generator? What spot on the generator?
Matt Huls
07-02-2013 20:08:13
When you say regulator output do you mean "B" or "BATT" to ammeter right?
Matt Huls
07-02-2013 19:42:41
The voltage regulator terminals are labeled "L" on one "BATT on one and "F" on one. What"s the "L" stand for. Does the "L" terminal wire to the "A" or "ARM" on the generator?
