TractorLinks.com
Show Parts for Model:
Re: Replacing 630 Automatic Fuel Shut-off
MSD
06-30-2013 09:07:53
"Todays" gas shouldn't be the problem. I haven't had a problem with any of mine for the last 5 years. It's more than likely the diaphragms your using that are not compatible. Get the original Deere one's and they will last.
GlenT
06-30-2013 09:50:37
 Re: Replacing 630 Automatic Fuel Shut-off in reply to MSD, 06-30-2013 09:07:53
They are original JD. They were replaced in August 2008 so maybe you will also need a change soon.
D-
06-30-2013 10:36:11
 Re: Replacing 630 Automatic Fuel Shut-off in reply to GlenT, 06-30-2013 09:50:37
Tired of replacing them after five years???
Gas is not the problem since they probably didn't last any longer back in the day.
When you fill your engine with gas you will regret your decision.
Tim S
06-30-2013 12:47:12
 Re: Replacing 630 Automatic Fuel Shut-off in reply to D-, 06-30-2013 10:36:11
Mine didn"t last that long a couple sets of Deere diagrams,,I got a sediment bowl assembly at TSC, and put a 1/8th" ball valve on the out side to make it easy to turn off,,end of the problem...
D-
06-30-2013 13:17:34
 Re: Replacing 630 Automatic Fuel Shut-off in reply to Tim S, 06-30-2013 12:47:12
That would work. Just wouldn't want too change w/o a way of shutting off gas.
Glen T did say 2008 that's pretty good.
Tim S
06-30-2013 12:46:42
Mine didn"t last that long a couple sets O Deere diagrams,,I got a sediment bowl assembly at TSC, and put a 1/8th" ball valve on the out side to make it easy to turn off,,end of the problem...
