Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Show Parts for Model:
Re: biased opinion/ethanol
Mike Aylward
06-29-2013 14:34:13
Much of the reason ethanol gets a bad rap is because it cleans the fuel system of crap left in your system by your 100% gas. Once the ethanol has done it's work and cleaned your fuel system you will wonder why you didn't do it sooner. And consider this: the general quality of all gasolines has deteriorated. The ethanol actually INCREASES the quality over the base gasoline. Blame the gas, not the ethanol. Mike
ArnieinChesterfieldVa
06-29-2013 14:51:44
 Re: biased opinion/ethanol in reply to Mike Aylward, 06-29-2013 14:34:13
Sorry I didn't mention that my concern is with longevity in a can. I have no problem running the fuel in my truck because new is pumped in on a weekly basis. What I do have a problem with is pumping into a 5 gallon can for small engines & it souring up within 3 months. Even my new John Deere lawn tractor manual warns if you have ethanol gas that's more than 30 days old, don't use it. That tells me a story right there. I use the good stabilizer sold at Tractor Supply but have my doubts that keeps it good for more than 5 months or so. Amazing what Washington & the "greens" throw at us without giving a crap if we want it.
Mr. Shelby, you rebuild carburetors. I'd like to hear your opinion. What kind of messes have you seen on these 2-cylinder carbs using 10%?
Mike Aylward
06-29-2013 16:51:20
 Re: biased opinion/ethanol in reply to ArnieinChesterfieldVa, 06-29-2013 14:51:44
I run ethanol in my chain saw and it stays in good shape. The oil seems to function as a stabilizer. Once again, it's not the ethanol that goes bad. It's the gas MIXED with the ethanol. Even conventional gasoline without ethanol goes bad. The old tractor that you cleaned the gunk out of it's fuel system could very well have been caused by 100% gasoline. All gasoline will go bad now sooner than it used to. Once again, it's NOT the fault of the ethanol. If it was, I wouldn't use it. I have for over 35 years without any problem. The only fuel that won't go bad is either aviation fuel or racing fuel. Anything else will. Mike
Copyright © 1997-2015 Yesterday's Tractor Co.
