1010 injector help
C. Dill
New User
I am considering installing JD Pencil injectors in my 1010. Mine came without injectors but were of the type that had the 1/4" NPT connector on the top. Would be great if I could get my hands on an original scrap one to verify placement of the pencil injectors.
What are you plans for a 1010 diesel? Restoration for a collection, hobby farm useage, odd jobs tractor on a farm or a primary tractor to earn your living?
Parts book is on the JD web site.You dd not state what serial number the tractor is.
http://jdpc.deere.com/jdpc/servlet/com.deere.u90490.partscatalog.view.servlets.HomePageServlet_Alt
TURBULENCE CHAMBER, INJECTION NOZZLE, AND GLOW PLUG (DIESEL)
(TRACTOR SERIAL NO. 010001-042000)
Cart KEY PART NO. PART NAME QTY TRACTOR SERIAL NO. REMARKS
1 T12186 PLATE 4 - 031000
2 AT11077 NOZZLE 4 - 031000
3 14H1080 NUT 24 - 021832 3/8"
14H1080 NUT 8 021833 - 031000 3/8"
4 T11219 STUD 8 - 031000
5 AT16745 CHAMBER 4 - 031000 (SUB FOR AT11043 AND AT14800)
T18532 CHAMBER 4 031001 - (SUB FOR T18366)
6 T11167 WASHER 4
7 AT11044 GLOW PLUG 1 - 013019 (SUB AT16144 AND AT16768)
........ GLOW PLUG 4 013020 - 031000 (SUB FOR AT13152 AND AT14773) (ORDER AT16144)
AT23537 GLOW PLUG 4 031001 - (SUB FOR AT16499)
8 T16331 GASKET 4 - 031000 (SUB FOR T11223)
9 19H1100 CAP SCREW 1 - 021832 3/8" X 1-3/8", (SUB FOR T11215 OR T19274)
10 T11214 STUD 8 - 015226 UPPER
19H1100 CAP SCREW 1 015227 - 021832 3/8" X 1-3/8", (SUB FOR T11215 OR T19274)
11 T19687 O-RING 4 (SUB FOR T11220)
12 T11221 WASHER 8
13 T11222 CHAMBER 4
14 T16573 PIN 4 (SUB FOR T11212) (LOWER TURBULENCE CHAMBER LOCATING PIN)
15 T18425 SPRING 4 (SUB FOR T12060, T12061, T12062, T12063, T12064, T12065 AND T16951)
16 T12056 SPACER 4 0.5 - 0.6MM (0.020" - 0.024")
T12057 SPACER 4 0.66 - 0.76MM (0.026" - 0.030")
T12058 SPACER 4 0.8 - 0.9MM (0.032" - 0.036")
T12059 SPACER 4 0.96 - 1.06MM (0.038" - 0.042")
17 AT16493 NOZZLE 4 (SUB FOR AT11733)
18 T12187 NUT 4
19 24M7096 WASHER 16 021833 - 10.500 X 18 X 1.600 MM
20 19H1800 CAP SCREW 16 021833 - 3/8" X 1-1/2"
21 AT16344 NOZZLE HOLDER 4 031001 -
22 T18179 NUT 4 031001 -
23 T18181 NUT 4 031001 -
24 T18180 HOUSING 4 031001 -
(TRACTOR SERIAL NO. 042001- )
1 T18986 NUT 1
2 R32529 SHIM 1 .1MM (.004") (SUB FOR T18971)
R32531 SHIM 1 .35MM (.014") (SUB FOR T18973)
3 R32539 GUIDE 1
4 T18970 SPRING 1
5 AT17242 SPINDLE 1
6 R48694 SCREW 1 (SUB FOR T18987)
7 T18984 GASKET 1
8 ........ HOUSING 1 (SUB AT17067)
9 AT17241 INJECTION NOZZLE 1
10 T18983 NUT 1
11 T18969 GASKET 1
12 AT17067 INJECTION NOZZLE 4
13 14H1080 NUT 8 - 053399 3/8"
14 19H1100 CAP SCREW 1 - 053399 (SUB FOR T11215 OR T19274)
15 ........ CHAMBER 1 - 053399 (SUB T19139 AND (2) 19H3219) (SUB FOR AT17398)
T19139 CHAMBER 4 053400 -
16 T19687 O-RING 4 (SUB FOR T11220)
17 T11221 WASHER 8
18 T11222 CHAMBER 4
19 T16573 PIN 4
20 19H3219 CAP SCREW 16 3/8" X 1-3/8"
21 24M7096 WASHER 16 10.500 X 18 X 1.600 MM
22 AT23537 GLOW PLUG 4 (SUB FOR AT16499)
23 19H3219 CAP SCREW 8 053400 - 3/8" X 1-3/8"
Again 1010s did not have pencil injectors. Perhaps you just were thinking all injectors are referred to as pencils?
Your engine is a converted gas as was a 706 IH and that sorry 5.7 Olds that GM tried in the late 70s.
The head you have has pre-combustion chambers and glow plugs. Deere used pencils only in direct injection engines.
The 560 farmall diesel tips will interchange with the 1010 diesel injectors.You can still get the farmall tips.
