Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Show Parts for Model:
Re: 1010 injector help
buickanddeere
06-29-2013 07:57:02
What are you plans for a 1010 diesel? Restoration for a collection, hobby farm useage, odd jobs tractor on a farm or a primary tractor to earn your living?
Parts book is on the JD web site.You dd not state what serial number the tractor is.
http://jdpc.deere.com/jdpc/servlet/com.deere.u90490.partscatalog.view.servlets.HomePageServlet_Alt
TURBULENCE CHAMBER, INJECTION NOZZLE, AND GLOW PLUG (DIESEL)
(TRACTOR SERIAL NO. 010001-042000)
Cart KEY PART NO. PART NAME QTY TRACTOR SERIAL NO. REMARKS
1 T12186 PLATE 4 - 031000
2 AT11077 NOZZLE 4 - 031000
3 14H1080 NUT 24 - 021832 3/8"
14H1080 NUT 8 021833 - 031000 3/8"
4 T11219 STUD 8 - 031000
5 AT16745 CHAMBER 4 - 031000 (SUB FOR AT11043 AND AT14800)
T18532 CHAMBER 4 031001 - (SUB FOR T18366)
6 T11167 WASHER 4
7 AT11044 GLOW PLUG 1 - 013019 (SUB AT16144 AND AT16768)
........ GLOW PLUG 4 013020 - 031000 (SUB FOR AT13152 AND AT14773) (ORDER AT16144)
AT23537 GLOW PLUG 4 031001 - (SUB FOR AT16499)
8 T16331 GASKET 4 - 031000 (SUB FOR T11223)
9 19H1100 CAP SCREW 1 - 021832 3/8" X 1-3/8", (SUB FOR T11215 OR T19274)
10 T11214 STUD 8 - 015226 UPPER
19H1100 CAP SCREW 1 015227 - 021832 3/8" X 1-3/8", (SUB FOR T11215 OR T19274)
11 T19687 O-RING 4 (SUB FOR T11220)
12 T11221 WASHER 8
13 T11222 CHAMBER 4
14 T16573 PIN 4 (SUB FOR T11212) (LOWER TURBULENCE CHAMBER LOCATING PIN)
15 T18425 SPRING 4 (SUB FOR T12060, T12061, T12062, T12063, T12064, T12065 AND T16951)
16 T12056 SPACER 4 0.5 - 0.6MM (0.020" - 0.024")
T12057 SPACER 4 0.66 - 0.76MM (0.026" - 0.030")
T12058 SPACER 4 0.8 - 0.9MM (0.032" - 0.036")
T12059 SPACER 4 0.96 - 1.06MM (0.038" - 0.042")
17 AT16493 NOZZLE 4 (SUB FOR AT11733)
18 T12187 NUT 4
19 24M7096 WASHER 16 021833 - 10.500 X 18 X 1.600 MM
20 19H1800 CAP SCREW 16 021833 - 3/8" X 1-1/2"
21 AT16344 NOZZLE HOLDER 4 031001 -
22 T18179 NUT 4 031001 -
23 T18181 NUT 4 031001 -
24 T18180 HOUSING 4 031001 -
(TRACTOR SERIAL NO. 042001- )
1 T18986 NUT 1
2 R32529 SHIM 1 .1MM (.004") (SUB FOR T18971)
R32531 SHIM 1 .35MM (.014") (SUB FOR T18973)
3 R32539 GUIDE 1
4 T18970 SPRING 1
5 AT17242 SPINDLE 1
6 R48694 SCREW 1 (SUB FOR T18987)
7 T18984 GASKET 1
8 ........ HOUSING 1 (SUB AT17067)
9 AT17241 INJECTION NOZZLE 1
10 T18983 NUT 1
11 T18969 GASKET 1
12 AT17067 INJECTION NOZZLE 4
13 14H1080 NUT 8 - 053399 3/8"
14 19H1100 CAP SCREW 1 - 053399 (SUB FOR T11215 OR T19274)
15 ........ CHAMBER 1 - 053399 (SUB T19139 AND (2) 19H3219) (SUB FOR AT17398)
T19139 CHAMBER 4 053400 -
16 T19687 O-RING 4 (SUB FOR T11220)
17 T11221 WASHER 8
18 T11222 CHAMBER 4
19 T16573 PIN 4
20 19H3219 CAP SCREW 16 3/8" X 1-3/8"
21 24M7096 WASHER 16 10.500 X 18 X 1.600 MM
22 AT23537 GLOW PLUG 4 (SUB FOR AT16499)
23 19H3219 CAP SCREW 8 053400 - 3/8" X 1-3/8"
Copyright © 1997-2015 Yesterday's Tractor Co.
