3010 Gas Hydraulic problems.
Hi, our one and only JD's hydraulic system has gone kuput. Time/118 degree weather has not yet allowed us to do any real checking, but I thought I post what we know, and see if any one knows whats wrong and what might be involved in fixing.
So, as stated its a 3010 Gas, and its a 1961 model according to the sn. At present, it has no lift/lower in the remote Hydraulic lines, AND the 3point wont go up. It however still has power steering and breaks.
Thx.
How lng since hyd filer was changed and sump screen cleaned? Next thing to do is check stand-by pressure which should be 2250 psi. It's possible the pressure control valve is stuck not allowing prssure back to scv & 3 pt.
Memory says the filter is new, but my Dads the mechanic, all I
really do is go on line to gain the wisdom of others, to thereby
help him. Don't know about the screen at all and Even if dad
did try that, it could need it again.
We plan to check pressures, but that was for a while why it got
pushed off: we had to order a gauge. Now we have the gauge,
but Arizona summers now hinder matters.
