TractorLinks.com
Show Parts for Model:
Re: Tx Jim / Tim S... 2510 fuel in he crankcase
Jethro Lilley
06-28-2013 16:45:24
I have taken the lift pump off and it checked OK. The engine runs like new. I think it's the shaft seals. I can remove the injector pump... no problem. What should I look for?
D-
06-28-2013 17:30:09
 Re: Tx Jim / Tim S... 2510 fuel in he crankcase in reply to Jethro Lilley, 06-28-2013 16:45:24
If you don't already know you need to tie the throttle arm back so as not to drop the governor weights.
Just replace the seals being very careful reinstalling the pump. It's very easy to roll or pinch the seal.
While the pump is off you might run your finger in the pilot tube to check for wear. If it's worn the pump will have to be disassembled.
Jethro Lilley
06-29-2013 02:31:56
 Re: Tx Jim / Tim S... 2510 fuel in he crankcase in reply to D-, 06-28-2013 17:30:09
OK, the governor is inside the injector pump. I gotcha. Thanks...
