bmiller36
I had the bearing on the lower countershaft go out. I removed the flywheel and trans shaft cover I took the sliding gear off but am stuck on how to get the lock nut off. Do you have to tap or bang on the slots untill loose? I think I can replace the bearing without taking the shaft out of the tractor. Am I on the right track or do I have to remove the top trans shafts first? Thanks Bob
