Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Show Parts for Model:
Re: 3020 lights
35 Chopper
06-23-2013 19:37:55
TX Jim, I confirmed the starter wiring and everything is per the drawing except we have two brown wires on the solinoid. I check voltage at the light switch as follows: Brown has 12V with Key on, Blue has 12V+? key on 12V-? with key off. Also checked voltage at lights: Inside (yellow wire) alwayse has 12V regardless of key position, Outside (green wire) responds to light switch. Really confusing.
Tx Jim
06-24-2013 05:13:14
 Re: 3020 lights in reply to 35 Chopper, 06-23-2013 19:37:55
Welcome to JD's 24 volt wiring!!!! I can't remember but are the 2 brown wires crimped in the same eyelet? It sounds as if the light switch isn't wired correctly. Have you double checked the wiring on light switch?
35 Chopper
06-24-2013 08:06:55
 Re: 3020 lights in reply to Tx Jim, 06-24-2013 05:13:14
Both browns are landed on the same solenoid post. The light switch wires have not been removed or unpluged for a verylong time and the lights have worked in tha last few months. I can confirm them later today. Thanks!
Copyright © 1997-2015 Yesterday's Tractor Co.
