Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Show Parts for Model:
Re: 3020 lights
Tx Jim
06-23-2013 04:21:53
I'm confused as to why you have "2" ground fuses? I agree with Tim to check the wires on the starter(blue & brown) and the circuit breakers(parts key #31)
35 chopper
06-23-2013 18:17:23
 Re: 3020 lights in reply to Tx Jim, 06-23-2013 04:21:53
TX Jim, You are correct one of the fuse links goes to ground (tran case) and the other to the wiring harness. I check the circuit breakers (continuity test) and they look O.K. We have double checked the starter and VR/gen wiring against the diagrams made before disassembly and they are correct. Could be this problem existed before the split. It's been a while since we used the lights. Any other ideas?
Tx Jim
06-23-2013 18:19:54
 Re: 3020 lights in reply to 35 chopper, 06-23-2013 18:17:23
The brown & blue wires power the lights and are labeled bat A & bat B on ign & light switches. Did you check the 2 circuit breakers under the dash? Some state that lights will burn without a ground connection. I prefer the lights grounded through the fenders to the axle housing. Do you have good grounds(neutral connections)? I still remember the color of the sealed beams when they get 24 volts to them.
This post was edited by Tx Jim at 18:24:53 06/23/13 2 times.
35 chopper
06-23-2013 18:32:42
 Re: 3020 lights in reply to Tx Jim, 06-23-2013 18:19:54
TX Jim, I checked the circuit breakers with a cotinuity tester and it shows they are closed. I assume you are refering to the ones mounted on the removable plate that holds the key and light switch?
35 Chopper
06-23-2013 18:44:03
 Re: 3020 lights in reply to 35 chopper, 06-23-2013 18:32:42
I did notice a couple of things looking at the starter pic. I think there is only one blue wire and two browns? I need to print the drawing out and double check. also not a jumper from 28 to the the solenoid post? Again I will double check. Thanks for your help.
35 Chopper
06-23-2013 19:37:55
 Re: 3020 lights in reply to 35 Chopper, 06-23-2013 18:44:03
TX Jim, I confirmed the starter wiring and everything is per the drawing except we have two brown wires on the solinoid. I check voltage at the light switch as follows: Brown has 12V with Key on, Blue has 12V+? key on 12V-? with key off. Also checked voltage at lights: Inside (yellow wire) alwayse has 12V regardless of key position, Outside (green wire) responds to light switch. Really confusing.
Tx Jim
06-24-2013 05:13:14
 Re: 3020 lights in reply to 35 Chopper, 06-23-2013 19:37:55
Welcome to JD's 24 volt wiring!!!! I can't remember but are the 2 brown wires crimped in the same eyelet? It sounds as if the light switch isn't wired correctly. Have you double checked the wiring on light switch?
35 Chopper
06-24-2013 08:06:55
 Re: 3020 lights in reply to Tx Jim, 06-24-2013 05:13:14
Both browns are landed on the same solenoid post. The light switch wires have not been removed or unpluged for a verylong time and the lights have worked in tha last few months. I can confirm them later today. Thanks!
