TractorLinks.com
Show Parts for Model:
Re: Hydraulic pump cavitation
Tx Jim
06-23-2013 04:06:43
Tim S said: (quoted from post at 22:28:52 06/22/13) The pressure regulating valve down on the right rear side under the floor board could be giving a problem, I had one in here a while back that I had to change the valve "and" the housing to get things going...
Also the SCV(if equipped) could be leaking causing the spraying by way of the return hose but since no leak is noticed with 3 pt down I think your tractors problem are the control valves. Another possibility is that the clearance on the valves is set "too close). This can externally be adjusted by turning screw(parts key #2) through a hole in the rockshaft housing.
This post was edited by Tx Jim at 04:14:15 06/23/13 2 times.
