TractorLinks.com
Show Parts for Model:
Re: removing g wheels
D-
06-22-2013 19:09:30
Can you loosen the bolts at all or if you have to cut them off then can you drive a wood splitting wedge behind the collar to loosen it?
Ray Durham
06-23-2013 11:50:09
 Re: removing g wheels in reply to D-, 06-22-2013 19:09:30
You may have to cut the wheel clamps off with a torch. Then, pick up used ones from a salvage yard. If you are restoring a JD two-banger it won't be the most expensive part you ever buy.
jdjack
06-23-2013 20:48:27
 Re: removing g wheels in reply to Ray Durham, 06-23-2013 11:50:09
Got them off. screwed 3 bolts from the out side and installed some strap steel so it would press on collar and not the bolts. heated collar and hit with air hammer and tightened screws. Thanks
