Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Show Parts for Model:
Re: removing g wheels
D-
06-22-2013 17:20:02
Are the bolts for the other wedge facing out? If so loosen them . Since the guy was able to tighten what should be the outer wedge bolts you should be able to get a wrench on them. Do the jack bolts move or are they frozen?
Maybe I'm thinking too new wheel design??? Are your axles rack and pinion or splined?
jdjack
06-22-2013 17:56:07
 Re: removing g wheels in reply to D-, 06-22-2013 17:20:02
you are thinking about the rack and pinion, these are splines with a tapper lock collar.
D-
06-22-2013 19:09:30
 Re: removing g wheels in reply to jdjack, 06-22-2013 17:56:07
Can you loosen the bolts at all or if you have to cut them off then can you drive a wood splitting wedge behind the collar to loosen it?
Ray Durham
06-23-2013 11:50:09
 Re: removing g wheels in reply to D-, 06-22-2013 19:09:30
You may have to cut the wheel clamps off with a torch. Then, pick up used ones from a salvage yard. If you are restoring a JD two-banger it won't be the most expensive part you ever buy.
jdjack
06-23-2013 20:48:27
 Re: removing g wheels in reply to Ray Durham, 06-23-2013 11:50:09
Got them off. screwed 3 bolts from the out side and installed some strap steel so it would press on collar and not the bolts. heated collar and hit with air hammer and tightened screws. Thanks
