Yesterday's Tractor Co.
Shop Now View Cart
Show Parts for Model:
Re: Hydraulic pump cavitation
Rick Rauchle
06-22-2013 07:43:52
Jim, I'm not sure what you ment by an ind valve for the loader, its a 146 loader plumbed into the ported cover on the filter. It still cavitates with the loader disc. and off the tractor.
David G
06-22-2013 16:36:09
 Re: Hydraulic pump cavitation in reply to Rick Rauchle, 06-22-2013 07:43:52
When you say loader is off the tractor, is the control valve off too?
Rick Rauchle
06-22-2013 16:56:53
 Re: Hydraulic pump cavitation in reply to David G, 06-22-2013 16:36:09
Yes, I still have cavitation when the loader and valve(all one unit)are removed from the tractor.Its attached to hyd.system with two quick the ported filter cover.
Tx Jim
06-22-2013 09:13:02
Some JD loaders are operated from the tractors selective control valves aka SCV's. Ind control valve is a spool valve either controlled by 2 levers or joystick. Some of the ind valves are convertible from open-center to closed center or vice-verse. The change over plug seal can blow causing closed center control valve problems. Disconnect the return hose from ported filter cover,plug filter cover,put return hose in bucket,crank engine with control valve in NEUTRAL if oil flows into bucket the FEL ind control is the hyd problem
Rick Rauchle
06-22-2013 16:51:00
 Re: Hydraulic pump cavitation in reply to Tx Jim, 06-22-2013 09:13:02
Well I went out to where the tractor is today. I disc. the elec. destroker and put in a test gauge, I had 2000lbs at the high pressure outlet on the main pump. I looked in the filler hole with the brush mower on the ground and everything looked good, I then lifted it up, and I could see abit of oil dripping and lightly spraying to the right of the rockshaft lift cylinder. Its pretty hard to see where its coming from. When I rebuilt the rockshaft I replaced the spools and o-rings, found no cracks.
