TractorLinks.com
Show Parts for Model:
Re: 2010 power steering
Jo Bird
06-21-2013 21:11:57
Phil
Besides the power steering, the pump also supplies oil to the transmission shafts so it needs to be made functional. As jasper and farmerzeb say make sure the pump lever is engaged and also clean the filter located in the bottom of the transmission case on the Rt side below the foot board, round cover with 3 bolts. It is a micro screen and tough to clean, the way I test it is to stand it on end and fill it with oil. If the oil is slow to run out it is not clean. If the pump is engaged and the filter is clean and you still do not have power steering check the proportioning valve. It's located in the round hole above the foot board Rt side. It's a little tough to get at, remove the 3/8 inch line to get the bolts out of the round cover as in the picture below. PS: it may be a flat cover as their was a design change in later serial #'s. Post back if you need more help..
Jo
Phil Puestow
07-12-2013 22:05:56
 Re: 2010 power steering in reply to Jo Bird, 06-21-2013 21:11:57
Thanks for the help. I got a manual to help. I got the filter out and it was completely plugged. Looks like the filter was never cleaned. I have a new leak under the rear end now that the pump works. It is pouring out of a small hole in the center of the rear end. Tried to find or look up where or what this hole is for and what seal may be gone. Tractor was cheap but I am paying for it now.
