TractorLinks.com
Show Parts for Model:
Re: Hydraulic pump cavitation
Tx Jim
06-21-2013 18:32:54
You can test trans pump with a hyd flowrater. JD utility tractor trans pumps are difficult to test.
D-
06-21-2013 19:21:52
 Re: Hydraulic pump cavitation in reply to Tx Jim, 06-21-2013 18:32:54
Does the three point drop by itself when you shut the engine off?
Tx Jim
06-22-2013 04:42:01
 Re: Hydraulic pump cavitation in reply to D-, 06-21-2013 19:21:52
Did you check the rockshaft control valves after the rebuild for leakage? This can be accomplished by looking in hyd filler hole with 3 pt raised,engine running to see that no oil is spraying. I presume this tractor has "no FEL".
This post was edited by Tx Jim at 04:43:20 06/22/13.
