Paul Van Benschoten
New User
The 850 tractor that I have has a Selective Control Valve from a 1050 tractor according to the pictures in the TM1192 manual that I received from Joe (Thanks Joe !).
No problem, as long as it works, I don't care. But does it work?
The inside lever (left lever when sitting in the seat) does not return to center when I let go. The outer lever does.
Should it?
When I let go of the lever, the loader bucket continues to curl. I have to move the lever back to center.
Is this a problem with the spring inside the control valve?
Should it?
