620 bolt removal
Im tearing apart my 620 clutch and I need to remove the bolt out of the crankshaft to get to the back half of the clutch. How do I do this whenever I try to turn the bolt the whole think turns. I can't figure it out. How do I remove this bolt. Thanks in advance
Try putting it in gear, engage the clutch and put the breaks on. Should hold to get it loose.
You usually can't get an impact on them due to the tire in the way. Put a box wrench on it and SMACK it with a hammer. Remember lefty loosey. Make sure you get it good and tight too. Many were ran too loose causing worn splines.
You can also pull the fylwheel cover off and get a helper to hold it still for you or wedge a jackstand or something up onto the ring gear to hold it.
