Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Show Parts for Model:
Re: should this 70 start?
Pete76NY
06-18-2013 21:14:43
Danny, sounds like they have it pretty well covered, only other suggestion I can make is that while you are checking the oil cup on the air cleaner try to make sure there are no rodent nests up in the air cleaner itself...they love that spot, if plugged it'll suck oil, and make ya run real rich. Remember this, if you do all that was suggested here (well most of it anyway, I wouldn't get into the expense of fluids and filters other than to make sure the levels are good before buying), and it's not broken, it will more than likely start, but it probably will not run well...nothing worse for cast iron JD carbs than sitting, they will clog inside with rust, and nothing short of actually cleaning out those passages with a drill bit or wire will get 'em cleaned...including soaking them in carb cleaner for days!
Let us know how ya make out!
