TractorLinks.com
Show Parts for Model:
Re: radio on 3020
D-
06-18-2013 20:12:18
Who won that heated discussion?
You have an ignition switch with a positive post and a negative post, a light switch with a positive and a negative post.
Now do you believe the lights are 24V bulbs. No they are 12V. The inner ones run off of one battery while the outer ones are off the other battery. The same way with the 12V idiot lights. As stated above the oil light and fuel guage won't work without the ground wire connected. The head lights don't work properly either. If the generator was a true 24V generator it would need only two posts. It has three since it charges two separate 12V systems. A true 24V starter would have only one post just as a 6V or a 12V starter. A true 24V system would require resistors to operate 12V lights. There are none except the one on the light switch for dimming one set of headlights.
I guess I won't be calling John T. Maybe that ringing is only in your ears :)
Tx Jim
06-19-2013 04:19:11
 Re: radio on 3020 in reply to D-, 06-18-2013 20:12:18
D-
WHOA!!!!!!!! John T or I need no explanation of JD's 24 volt systems. I spent too many years in a JD dealers service dept explaining to technicians about the 24 V systems. Just research the archives for some interesting reading and you will understand my previous statement.
FYI the statement I made about John T's phone ringing was intended as sort of a joke to him.
D-
06-19-2013 15:05:48
 Re: radio on 3020 in reply to Tx Jim, 06-19-2013 04:19:11
So did I.
Also I knew you were joking with the comment... so was I.
