Hello Hugh McKinney
James Howell
Look what I found in stock at Ag Power in Mt. Pleasant, TX.
<a href="http://s200.photobucket.com/user/jameslloydhowell/media/John%20Deere%20Equipment/Vernon/Lubrication/IMG_3501.jpg.html" target="_blank">
IMG_3501.jpg" width="650" border="0" alt=" photo IMG_3501.jpg"
</a>
They had 14 quarts in stock; wonders never cease.
Thanks for the heads up! And for all the kind words in referencing the question by Danny Sherril about starting a long-idle "70". By the way, I'm about to start the job of replacing the large O-rings on my power steering unit on my "70" with narrow front...the unit works just fine, it simply leaks a lot of fluid down the pedestal. Should I go to the local JD dealer for parts, or use an aftermarket source? Thanks, Hugh
I would recommend your local JD dealer first for pricing and availability of the large O-rings.
If they are available, then you can be confident that they will work on the tractor.
If they are overpriced compared to the aftermarket source; then you can decide which is the better quality product.
Hope this helps.
