JD 401 industrial motor oil capacity
37chief
Location
California
I drained the oil in my 401. Seamed like it should be more in the pail. I checked my manual it said 6 qts. then I looked up on another sight about my 401 it said 9 qts. I would think the manual will be correct. Any thoughts. I can't go by the dip stick as Is is not original. Stan
(quoted from post at 20:25:31 06/18/13) The 401 would be the same as the 1520 ag tractor,it should be 6 quarts.
1520 has 3 cyl engine while 401 has a 4 cyl engine.
