Yesterday's Tractor Co.
Shop Now View Cart
Show Parts for Model:
Re: should this 70 start?
06-18-2013 10:13:03
Do the things HUGH mentioned, and also take an oil can with good squirt pressure and squirt a couple good pumps into the plug holes to lubricate the cylinder walls for cranking. Cranked my 52 G up a while back after it sat for 5 or 6 years. Cylinder walls are pretty dry after that much time.
Hugh McKinney
06-20-2013 19:03:39
 Re: should this 70 start? in reply to DP, 06-18-2013 10:13:03
Thanks for the good publicity! Hugh
06-18-2013 18:46:48
You might want check if there is any water or other fluid in the cylinders before turning it over to avoid hydro-locking the engine. If there is water in a cylinder the piston, rings and/or the valves may be stuck.
