The operator's manual recommends three engine oil weights depending on air temperature.<li>Above 90<sup>o</sup>F. S.A.E. 30</li><li>32<sup>o</sup>F. to 90<sup>o</sup>F. S.A.E. 20</li><li>Below 32<sup>o</sup>F. S.A.E. 10-10W</li>
We use 15W-40 Diesel oil in all our tractors.
The photo below shows the engine oil drain plug; the oil filter is on the left and oil pump is on the right.
<a href="http://s200.photobucket.com/user/jameslloydhowell/media/John%20Deere%20Equipment/Easy/Fluid%20Plugs/4a9378c6-e62f-44a7-9fe9-c5e9158d87e2.jpg.html" target="_blank">
</a>
Remove the breather stack and filter to pour in the oil.
<a href="http://s200.photobucket.com/user/jameslloydhowell/media/John%20Deere%20Equipment/Easy/Crankcase%20Breather/e663f3c2-2fb0-4518-ac91-61e87479929e.jpg.html" target="_blank">
</a>
Open the oil level test cock and pour in the oil.
<a href="http://s200.photobucket.com/user/jameslloydhowell/media/John%20Deere%20Equipment/Easy/Fluid%20Plugs/0ce10488-59e8-469f-b1fb-2b71dc044049.jpg.html" target="_blank">
</a>
Add oil until it drips out the oil level test cock; when the oil drips out it is full.
The operator's manual recommends two transmission oil weights depending on air temperature.<li>0<sup>o</sup>F. and Up S.A.E. 90</li><li>Below 32<sup>o</sup>F. S.A.E. 80</li>
We use 140W GL1 oil in all our tractors.
The photos below show the two transmission drain plugs.
<a href="http://s200.photobucket.com/user/jameslloydhowell/media/John%20Deere%20Equipment/Easy/Fluid%20Plugs/b4fb2004-a0be-494a-865a-56d2396abdf3.jpg.html" target="_blank">
</a>
<a href="http://s200.photobucket.com/user/jameslloydhowell/media/John%20Deere%20Equipment/Easy/Fluid%20Plugs/3b8b298d-9adb-45b7-83d6-d43bf5b531ef.jpg.html" target="_blank">
</a>
The photo below shows the transmission fill plug.
<a href="http://s200.photobucket.com/user/jameslloydhowell/media/John%20Deere%20Equipment/Easy/Fluid%20Plugs/4c102246-ff92-4eba-a3df-a0aeab3e8653.jpg.html" target="_blank">
</a>
Add transmission oil to the bottom of the threads; takes about 7 gallons.
The photo below shows the oil cup on the bottom of the air cleaner.
<a href="http://s200.photobucket.com/user/jameslloydhowell/media/John%20Deere%20Equipment/Easy/Oil%20Cup/IMG_3451.jpg.html" target="_blank">
</a>
Be sure to add clean oil to the cup.
Hope this helps.
