Pony motor water pump, JD 80
Dan in Ohio
Location
Mid-Ohio
Getting ready to remove the water pump to replace both seals. Want to know if it will really slip under the hydraulic lines without disconnecting them like the service manual says. Has anyone replaced the water pump seals only to find out later that they were not the source of coolant in the pony crankcase?
Replacing the seals will not fix it. The impeller has a groove in it. We sell them rebuilt (exchanged) for $100.
