john deere 2020
I have a JD 2020 Diesel that i am fixing-up, and the wiring is a real mess. Is it better to teasr it all out and order a wiring harness and start over, or is that a nightmare in itself. I could just patch splice some new wires together but I'd rather not. Wiring problems always baffle me. Also: the serial number plate is missing and I odn;t know what year it is...any tricks to findoing out? Thanks.
If I was doing it I would start fresh and make my own wiring harness. If you are inexperienced with wiring you may be better off buying a new harness. If you just patch it you will likely have more problems in the future. Either way get a good wiring diagram to work from.
