michael ibach
New User
first and foremost, thank you all for the fixes, pointers, and help with my jd 2010. i've been dealing with this choke issue for sometime. the engine will only run with the choke pulled out about 1/3. i just finished painting and had it delivered to my rec land. while riding the tractor and not touching the throttle the engines rpm would increase. i would then have to adjust the throttle to decrease the rpms. this cycle was random. the tractor was never under any load other than gear two. any ideas? could this have anything to do with the float? i rebuilt the carb and replaced a faulty float. should i have adjusted the height of the float? thanks for all of your help.
