TractorLinks.com
Show Parts for Model:
Re: 2020 JD Hydrolic Proublems????
Tx Jim
06-13-2013 04:10:56
XL cid A
As Todd stated leaking RS valves have a history of causing hyd problems on utility tractors. With 3pt raised,engine running look inside hyd filler hole for spraying oil. SC's if so equipped or power steering valves are other sources for internal high pressure leaks. Does tractor have a FEL with an ind control valve> Does tractor have hyd ind pto or hi-lo?
RS= rockshaft valvw that controls 3pt(three point hitch) FEL =frt end loader
hyd=hydraulics
hi-lo=hyd hi-lo aka 2 speed
This post was edited by Tx Jim at 09:25:32 06/13/13.
XL CID A
06-13-2013 06:53:00
 Re: 2020 JD Hydrolic Proublems???? in reply to Tx Jim, 06-13-2013 04:10:56
Not sure on what all of your abbreviations mean but no hydrolic hook ups or control valve no hydrolic PTO ether
buickanddeere
06-13-2013 07:23:26
 Re: 2020 JD Hydrolic Proublems???? in reply to XL CID A, 06-13-2013 06:53:00
Hydraulic is spelled as " hydraulic" .
XL CID A
06-13-2013 07:27:13
 Re: 2020 JD Hydrolic Proublems???? in reply to buickanddeere, 06-13-2013 07:23:26
Really happy you can spell ! That doesn't help the issue any. But thanks for the reply!
