Raven cruser
Anonymous-0
I have a raven cruser ,I am not happy with.On hot days it will not even power up.It seems to lose signal at times for no reason.I sent it back for repairs got a $300.bill no better.Replaced coax cable no change.E mailed Raven no reply .Dealer not mutch help.I am interested in other peoples experience. thank you Lloyd
I have a cruizer II that I just started using this spring. So far so good, but it will turn on as soon as the power is hooked up to it- the switch doesn't have to be pushed. I need to look into that. But it is accurate. What antenna do you have- the taller helix type or the short patch antenna?
You may be able to get more input on this by going to the precision talk forum of newagtalk.com
Good Luck
Lon
