Deere 630 Amp Meter question...
phess11
Ok, I am new to Amp Meters, but with the tractor off and the lights turned on, shouldn't the amp meter read negative amps? Then when you start the tractor, should the amp meter read positive amps due to charging? Mine just seems to hover around zero. Thanks for your help.
phil
Yep, thats what a good working ammeter should do with a good working charging system...They can go bad and the needle get corroded or stuck...See if passing a magnet over its face makes it move???
My Charging troubleshooting procedure may help
John T
John Ts Troubleshooting
